首頁>>>技術(shù)>>>融合通信
基于IMS的固定和移動網(wǎng)絡(luò)融合
糜正琨 2008/06/03
  摘要:3GPP提出的IP多媒體子系統(tǒng)(IMS)技術(shù)體現(xiàn)了通信網(wǎng)和因特網(wǎng)技術(shù)的結(jié)合、下一代網(wǎng)絡(luò)和3G網(wǎng)絡(luò)技術(shù)的結(jié)合,已受到通信界和信息技術(shù)界的廣泛認同,成為固定和移動網(wǎng)絡(luò)融合的核心技術(shù)。其網(wǎng)絡(luò)融合綜合了互聯(lián)網(wǎng)IP技術(shù)、軟交換技術(shù)和蜂窩核心網(wǎng)技術(shù),業(yè)務(wù)融合綜合了開放式Parlay/OSA技術(shù)和WebServices技術(shù),管理融合綜合了電信網(wǎng)管理、IP網(wǎng)絡(luò)管理和策略控制技術(shù)。面對互聯(lián)網(wǎng)的嚴峻挑戰(zhàn),各個標準化組織正通力合作推進IMS的發(fā)展,統(tǒng)一IMS、業(yè)務(wù)代理和有管理的P2P業(yè)務(wù)是進一步研究的重要內(nèi)容。
  關(guān)鍵詞:IP多媒體子系統(tǒng);網(wǎng)絡(luò)融合;業(yè)務(wù)融合
  Abstract:IPMultimediaSubsystem(IMS) proposed by 3GPP embodies an integration of communication network with Internet technology and a fabrication of Next Generation Network (NGN) with 3G technology. IMS has been widely acknowledged in telecom industry and Information Technology (IT) as the core technology for Fixed-Mobile Convergence (FMC). Network convergence is the integration of Internet IP, SoftSwitch and cellular core network technology. Service convergence is the synthesis of open Parlay/OSA technology and web service technology. Management convergence is the interfusion of telecom network, IP network management and policy control technology. To cope with a grim challenge from Internet, all standardization organizations are interacting to push forward the further development of IMS. A unified IMS, proxy service and managed P2P service are important subjects for further research.
  Keywords:IPmultimediasubsystem; network convergence; service convergence
  基金項目:國家自然科學基金資助項目(60472105)
  二十世紀末,隨著Internet的飛速發(fā)展,通信業(yè)界改變了以ATM交換技術(shù)為基礎(chǔ)構(gòu)建全球信息基礎(chǔ)設(shè)施的導向,確立了以IP路由技術(shù)為核心的下一代網(wǎng)絡(luò)(NGN)發(fā)展方向。固定通信網(wǎng)率先以VoIP為突破口,提出了軟交換組網(wǎng)技術(shù)和Parlay開放式業(yè)務(wù)技術(shù);IETF重用互聯(lián)網(wǎng)技術(shù)框架提出了IP網(wǎng)絡(luò)通信控制的會話啟動協(xié)議(SIP)技術(shù);以3GPP為代表的移動通信界將上述技術(shù)和蜂窩移動核心網(wǎng)技術(shù)結(jié)合起來,以實現(xiàn)多媒體業(yè)務(wù)為目標,提出了IP多媒體子系統(tǒng)(IMS)技術(shù),很快受到通信界和信息技術(shù)界的廣泛認同,成為固定和移動網(wǎng)絡(luò)融合(FMC)的核心技術(shù),并沿著未來信息通信網(wǎng)絡(luò)融合技術(shù)的定位方向不斷發(fā)展前進。
  1.IMS國際標準研究
  3GPP采用和其他標準化組織密切合作的方式制訂IMS技術(shù)標準,并依靠各國通信界的協(xié)同不斷發(fā)展和完善(如表1所示)。其中,最重要的合作就是和IETF聯(lián)合開發(fā)了IMS網(wǎng)絡(luò)的核心控制協(xié)議SIP[1],共同研究SIP的擴展和應(yīng)用。另一個重要的合作是和Parlay組織聯(lián)合開發(fā)了支持開放式業(yè)務(wù)提供的Parlay/開放業(yè)務(wù)接入(OSA)應(yīng)用程序接口(API),將源于固定智能網(wǎng)結(jié)構(gòu)開放的Parlay技術(shù)引入IMS網(wǎng)絡(luò)的OSA結(jié)構(gòu)[2]。最重要的協(xié)同就是ETSI的TISPAN研究組和ITU-T提出了IMS中融入固定接入的技術(shù)[3],另一個重要的協(xié)同是OMA組織提出了許多基于IMS實現(xiàn)的業(yè)務(wù)規(guī)范和技術(shù)[4]。
  3GPP依照UMTS 3G移動通信系統(tǒng)的系列標準版本定義了IMS的分階段演進計劃[5],如表2所示。其中,2002年完成的R5是第一個全IP移動網(wǎng)絡(luò)標準,它將核心網(wǎng)歸為一個統(tǒng)一的基于IP的分組(PS)域,具有服務(wù)質(zhì)量(QoS)保證,能夠提供各種類型的多媒體增值業(yè)務(wù),其核心技術(shù)標準就是IMS。R6進一步完善IMS接口和功能,增加對于WLAN的接入支持,并研究IMS域的計費和QoS控制技術(shù)。R7融合TISPAN關(guān)于NGN的研究標準,增加對于xDSL接入技術(shù)的支持,提出策略控制與計費(PCC)技術(shù)以及WLAN/3G語音連續(xù)通信的話音連接連續(xù)(VCC)技術(shù)。正在研究中的R8將協(xié)同各個標準化組織的工作,研究支持組合業(yè)務(wù)的業(yè)務(wù)代理技術(shù)以及下一步的統(tǒng)一IMS架構(gòu)。
  2.以IMS為核心的FMC技術(shù)
  按照上述思想提出的IMS分層網(wǎng)絡(luò)結(jié)構(gòu)如圖1所示,圖1演示出了不同標準版本的演進過程。底層為以IPv4/IPv6為核心技術(shù)的傳送層,包括話音、視頻、數(shù)據(jù)等各種媒體在內(nèi)的數(shù)據(jù)流既可經(jīng)由2G/3G移動網(wǎng)接入技術(shù)接入網(wǎng)絡(luò),也可經(jīng)由Wi-Fi、DSL等固定網(wǎng)寬帶接入技術(shù)接入網(wǎng)絡(luò),但所有媒體流均以IP分組的形式在網(wǎng)絡(luò)中傳輸,網(wǎng)絡(luò)運營商構(gòu)建統(tǒng)一的IP寬帶網(wǎng)絡(luò)為所有用戶服務(wù),體現(xiàn)了以IP為核心的網(wǎng)絡(luò)融合。上層為以信息技術(shù)為核心的業(yè)務(wù)/應(yīng)用層,業(yè)務(wù)運營商通過部署在各類應(yīng)用服務(wù)器中的業(yè)務(wù)邏輯向端用戶提供增值業(yè)務(wù),業(yè)務(wù)提供獨立于用戶的接入技術(shù),體現(xiàn)了以信息與通信技術(shù)(ICT)為核心的業(yè)務(wù)融合,并通過API調(diào)用融合通信網(wǎng)的能力。中間層就是以SIP為核心技術(shù)的IMS控制層,向下對傳送層的IP多媒體通信進行呼叫控制和管理,向上為業(yè)務(wù)應(yīng)用層提供調(diào)用通信網(wǎng)能力的開放式接口,實現(xiàn)業(yè)務(wù)層和網(wǎng)絡(luò)層的分離,支持獨立于網(wǎng)絡(luò)運營商的業(yè)務(wù)運營商的形成,體現(xiàn)了多媒體業(yè)務(wù)的融合控制與管理。
  2.1 網(wǎng)絡(luò)融合技術(shù)
  IMS網(wǎng)絡(luò)融合的基本思想是將互聯(lián)網(wǎng)IP技術(shù)、源于固定網(wǎng)演進的軟交換技術(shù)和移動核心網(wǎng)技術(shù)有機地結(jié)合起來,實現(xiàn)固定和移動通信網(wǎng)融合的目標。
  首先,IMS鑒于VoIP的成功應(yīng)用,在承載層摒棄了長期以來在傳統(tǒng)電信網(wǎng)中占主導地位的電路交換(CS)域,采用基于IP技術(shù)的單一的PS域傳輸各種媒體和信令數(shù)據(jù)流,即首次提出在通信網(wǎng)中采用全IP承載網(wǎng)絡(luò),使之成為通信網(wǎng)融合的底層基礎(chǔ)。
  其次,在業(yè)務(wù)組網(wǎng)上繼承蜂窩移動通信系統(tǒng)特有的網(wǎng)絡(luò)技術(shù),沿用原籍網(wǎng)絡(luò)和訪問網(wǎng)絡(luò)的概念,繼續(xù)采用擴展的移動性管理技術(shù)以及集中設(shè)置的網(wǎng)絡(luò)數(shù)據(jù)庫支持用戶漫游和切換。在2G網(wǎng)絡(luò)歸屬位置寄存器(HLR)的基礎(chǔ)上擴展形成IMS至關(guān)重要的網(wǎng)元原籍用戶服務(wù)器(HSS),存儲包括位置信息、認證授權(quán)信息、用戶文檔以及歸屬SIP服務(wù)器在內(nèi)的處理多媒體會話所需的各種用戶信息。因此,IMS系統(tǒng)在靈活提供IP多媒體業(yè)務(wù)的同時仍保持移動通信的所有特點,體現(xiàn)了移動通信網(wǎng)絡(luò)技術(shù)和Internet技術(shù)的有機結(jié)合。
  另外,在異構(gòu)網(wǎng)絡(luò)互通和異構(gòu)終端接入上借鑒軟交換組網(wǎng)技術(shù),通過網(wǎng)關(guān)實現(xiàn)與傳統(tǒng)固定及移動網(wǎng)絡(luò)的互通,設(shè)有信令網(wǎng)關(guān)(SGW)、媒體網(wǎng)關(guān)(MGW)、媒體網(wǎng)關(guān)控制器(MGCF)等網(wǎng)元,而且在MGCF和MGW也采用IETF和ITU-T共同制訂的H.248協(xié)議。在用戶接入側(cè),通過相應(yīng)接入網(wǎng)關(guān)和服務(wù)器的設(shè)置,不但可以接入移動終端,也可以接入固定電話終端、多媒體終端、PC機等,接入方式不限于蜂窩射頻接口,也可以是無線的WLAN、WiMAX,或者是有線的LAN、DSL、同軸電纜等技術(shù)。因此,IMS系統(tǒng)不但適用于移動網(wǎng)絡(luò),同樣也適用于固定網(wǎng)絡(luò),這充分體現(xiàn)了固定/移動網(wǎng)絡(luò)的融合。
  同時,IMS借鑒通信網(wǎng)的交換控制技術(shù),在IP承載層之上引入了集中的呼叫/會話控制層。但是由于其下層已不是傳統(tǒng)的電路交換網(wǎng),而是IP分組網(wǎng),因此IMS不再采用電信網(wǎng)信令,而是最大限度地重用Internet技術(shù)和協(xié)議。控制信令放棄使用ITU-T定義的在綜合業(yè)務(wù)數(shù)字網(wǎng)(ISDN)信令基礎(chǔ)上開發(fā)的成熟的H.323協(xié)議簇,選用了雖然并未成熟然而在技術(shù)上卻簡單而又易于擴展的SIP協(xié)議。其核心網(wǎng)元呼叫會話控制功能(CSCF)相當于SIP代理服務(wù)器,除了完成SIP消息轉(zhuǎn)發(fā)功能以外,還負責多媒體通信的呼叫控制。關(guān)于SIP消息的路由,對于SIP終端用戶,重用域名系統(tǒng)(DNS)協(xié)議進行地址解析;對于使用傳統(tǒng)電話號碼的終端用戶,重用IETF開發(fā)的電話號碼映射(ENUM)協(xié)議進行地址解析。由于大部分網(wǎng)絡(luò)接口采用的都是Internet協(xié)議,因此,IMS系統(tǒng)不但支持3G用戶之間基于IP網(wǎng)絡(luò)的多媒體通信,而且也能毫無困難地支持3G用戶和Internet用戶之間的通信。
  2.2 業(yè)務(wù)融合技術(shù)
  業(yè)務(wù)融合是IMS更高層次的融合,也是對于未來異構(gòu)信息通信網(wǎng)絡(luò)更為重要的深層次的融合。從網(wǎng)絡(luò)平滑演進的角度考慮,IMS支持3種業(yè)務(wù)提供方式。
  第一種方式是繼續(xù)重用固定和移動智能網(wǎng)技術(shù),由業(yè)務(wù)控制點(SCP)提供網(wǎng)絡(luò)運營商的簽約智能業(yè)務(wù),以保證融合網(wǎng)絡(luò)仍然能提供原來網(wǎng)絡(luò)中的所有增值業(yè)務(wù)。其技術(shù)上的更新只是原來始終和交換機位于一體的業(yè)務(wù)交換功能(SSF)和CSCF分離,成為獨立的IM-SSF。
  第二種方式是重用SIP網(wǎng)絡(luò)的業(yè)務(wù)技術(shù)。由于IMS控制層采用的是SIP協(xié)議,因此很自然地可以通過設(shè)置各種SIP服務(wù)器,利用互聯(lián)網(wǎng)中廣泛使用的公共網(wǎng)關(guān)接口(CGI)、Servlet、JavaBean、呼叫處理語言(CPL)等技術(shù),向用戶提供各種業(yè)務(wù)應(yīng)用。
  第三種方式稱之為Parlay/OSA業(yè)務(wù)架構(gòu),即重用已經(jīng)在軟交換網(wǎng)絡(luò)中應(yīng)用的Parlay技術(shù),通過和Parlay組織的密切合作,聯(lián)合開發(fā)調(diào)用IMS網(wǎng)絡(luò)能力的API,實現(xiàn)基于API的開放式業(yè)務(wù)提供,由業(yè)務(wù)層的OSA應(yīng)用服務(wù)器(AS)提供業(yè)務(wù)應(yīng)用。這些應(yīng)用服務(wù)器既可以屬于網(wǎng)絡(luò)運營商,也可以屬于獨立的第三方業(yè)務(wù)運營商,從而使通信網(wǎng)由封閉的網(wǎng)絡(luò)成為開放的網(wǎng)絡(luò),使業(yè)務(wù)層和網(wǎng)絡(luò)控制層真正分離。尤其是,3GPP又針對常用的API定義了Web Services接口,使得IMS業(yè)務(wù)應(yīng)用可以方便地和互聯(lián)網(wǎng)中的Web服務(wù)相結(jié)合,實現(xiàn)通信網(wǎng)和Internet的業(yè)務(wù)融合。因此,Parlay/OSA代表了IMS的發(fā)展方向,是業(yè)務(wù)融合的核心技術(shù)。
  2.3 管理融合技術(shù)
  IMS在業(yè)務(wù)管理和運營管理上,充分重用電信網(wǎng)的運營支撐系統(tǒng)(OSS)和業(yè)務(wù)支撐系統(tǒng)(BSS)技術(shù);在網(wǎng)絡(luò)管理上借鑒IP網(wǎng)絡(luò)接入認證技術(shù)和安全技術(shù);在QoS控制和計費上提出了基于策略控制的PCC技術(shù)。
  3.IMS面臨互聯(lián)網(wǎng)的挑戰(zhàn)
  由于互聯(lián)網(wǎng)應(yīng)用的快速擴張,技術(shù)的不斷更新,尤其是理念的沖突,使得IMS正受到互聯(lián)網(wǎng)的嚴峻挑戰(zhàn)。
  首先,互聯(lián)網(wǎng)的應(yīng)用直接架構(gòu)在網(wǎng)絡(luò)層之上,通常采用結(jié)構(gòu)瀏覽器/客戶/服務(wù)器(B/C/S),業(yè)務(wù)提供依賴于服務(wù)器和終端智能,沒有網(wǎng)絡(luò)控制層的概念,其基本思想是網(wǎng)絡(luò)應(yīng)盡可能簡單,以確保其可擴展性。因此,互聯(lián)網(wǎng)人士認為IMS和傳統(tǒng)電話網(wǎng)沒有本質(zhì)的差別,只是承載層換成IP形式而已,甚至認為IMS最終將由于不堪自身重負而告失敗。
  其次,互聯(lián)網(wǎng)始終強調(diào)內(nèi)容為王,認為連接是網(wǎng)絡(luò)必須提供的基本功能,網(wǎng)絡(luò)應(yīng)該通過和內(nèi)容提供商的合作,通過附著在內(nèi)容后面的廣告等后端服務(wù)贏利,而不是依靠連接贏利。有些IT業(yè)主流企業(yè)甚至提出網(wǎng)絡(luò)中立說[6],即網(wǎng)絡(luò)是信息社會的公共資源,應(yīng)該公平地提供給內(nèi)容服務(wù)商。他們淡化運營商的角色,不重視運營管理、計費管理等技術(shù),而這恰恰是IMS的重要技術(shù)之一。
  更為嚴重的是,近年來市場上迅猛發(fā)展的P2P業(yè)務(wù)對IMS構(gòu)成了直接的威脅[7]。P2P是應(yīng)用層面的自組織技術(shù),依賴于計算終端的協(xié)同合作可在網(wǎng)絡(luò)帶寬并不十分寬裕的條件下獲得所需的服務(wù)。它擺脫了對于集中式網(wǎng)絡(luò)基礎(chǔ)設(shè)施的依賴,完全不需要IMS控制層的干預。雖然,P2P業(yè)務(wù)消耗了大量的網(wǎng)絡(luò)資源,存在尚未解決的安全、知識產(chǎn)權(quán)等問題,然而這項創(chuàng)新技術(shù)已經(jīng)獲得許多客戶,特別是年輕群體的認同,是不可忽視的技術(shù)發(fā)展方向。
  IMS必須在這樣的挑戰(zhàn)性環(huán)境中確定其定位,尋求其發(fā)展的方向。
  4.IMS技術(shù)的發(fā)展方向
  無論從技術(shù)上還是應(yīng)用目標上說,IMS首先是一個FMC技術(shù)。因此,首要考慮的是如何將IMS技術(shù)和NGN結(jié)合起來,支持多種接入,特別是固定接入技術(shù)。需要解決的問題包括:固定終端接入時的地址穿越,業(yè)務(wù)邊界控制設(shè)備(SBC)技術(shù),不同類型終端的認證鑒權(quán),移動終端漫游管理和固定終端游牧管理,基于域名的路由機制等。各國提出了不少解決方案,其研究歸口于TISPAN和ITU-T。
  經(jīng)過多年的探索,業(yè)界取得共識網(wǎng)絡(luò)演進必須基于業(yè)務(wù)驅(qū)動的策略。必須指出的是,雖然基于SIP技術(shù)的IMS支持的業(yè)務(wù)從語音業(yè)務(wù)擴展到了寬帶多媒體業(yè)務(wù),然而其控制機理本質(zhì)上還是源于傳統(tǒng)電信網(wǎng),因此它最適合于提供的還是諸如VoIP、集群話音、集群視頻等實時會話型業(yè)務(wù),諸如Web、電子商務(wù)等純數(shù)據(jù)型業(yè)務(wù)并不適合由IMS提供,其他許多有前景的業(yè)務(wù),如流媒體業(yè)務(wù)、IPTV、消息類業(yè)務(wù)等的確IMS已提出或正在積極研究其提供方法,但是已有其他的非IMS提供方式。因此,切不要認為IMS是包羅萬象的,更確切地說,IMS是電信界提出的網(wǎng)絡(luò)融合技術(shù),考慮得更多的必然就是和傳統(tǒng)電信業(yè)務(wù)模式類似的業(yè)務(wù)。為了使IMS在未來融合的信息通信網(wǎng)絡(luò)中繼續(xù)保持其重要的地位,在積極研究擴大IMS業(yè)務(wù)能力的同時,必須研究新的體系結(jié)構(gòu)既能夠包容IMS型業(yè)務(wù),也能夠包容非IMS型業(yè)務(wù),由此形成融合的開放式的業(yè)務(wù)平面。這就是熱點研究之中的業(yè)務(wù)代理技術(shù),實際上就是架構(gòu)在IMS之上的綜合業(yè)務(wù)平臺,如圖2所示。它至少能夠提供4大類業(yè)務(wù):IMS類業(yè)務(wù)、消息類業(yè)務(wù)、流媒體業(yè)務(wù)、Web業(yè)務(wù)以及它們的組合,也就是說,除了IMS系統(tǒng)的SIP協(xié)議和API以外,業(yè)務(wù)平臺還應(yīng)能支持其他眾多的非IMS系統(tǒng)協(xié)議和接口,由此構(gòu)成融合的業(yè)務(wù)層。IMS系統(tǒng)是其中的一個重要組成部分,擔負起通信網(wǎng)絡(luò)的融合重任。
   目前各個標準化組織正通力合作推進統(tǒng)一IMS的研究,也就是在原來基于SIP協(xié)議的核心IMS的基礎(chǔ)上,擴展其他接口和協(xié)議,支持各種接入方式和網(wǎng)絡(luò)互通,組合各種業(yè)務(wù)提供方式,使之真正成為信息通信網(wǎng)絡(luò)融合的基礎(chǔ)。已同意該項研究歸總于3GPP,即現(xiàn)在剛剛起步的R8研究。
  最后需要強調(diào)的一點是,IMS的優(yōu)勢在于它是一個安全可靠、具有服務(wù)質(zhì)量保證的網(wǎng)絡(luò)系統(tǒng),這正是通信網(wǎng)區(qū)別于互聯(lián)網(wǎng)的重要特點,因此,IMS必須繼續(xù)十分重視融合管理技術(shù)的研究,確;贗MS的網(wǎng)絡(luò)是一個可運營、可管理和可贏利的網(wǎng)絡(luò)。對于P2P這樣典型的互聯(lián)網(wǎng)業(yè)務(wù)模式,雖然其發(fā)展勢頭十分迅猛,但是人們也意識到了其中存在的嚴重的安全問題和網(wǎng)絡(luò)擴展性的問題,通信界已改變簡單的圍堵思路,開始將P2P引入通信網(wǎng),研究有管理的P2P業(yè)務(wù)技術(shù),并已提出基于IMS的P2P管理架構(gòu)和技術(shù)。
  5.結(jié)束語
  IMS由通信界提出,其直接目標是支持固定和移動網(wǎng)絡(luò)融合,長遠目標是支持范圍更廣的信息通信網(wǎng)絡(luò)融合。融合技術(shù)包括基于IP的融合承載層、基于SIP的融合控制層和基于API的融合業(yè)務(wù)層,其中業(yè)務(wù)融合是最為重要的。其區(qū)別于互聯(lián)網(wǎng)融合的一個重要特點是,IMS融合網(wǎng)絡(luò)應(yīng)是一個具有服務(wù)質(zhì)量保證的可靠可信的網(wǎng)絡(luò)。但是IMS的發(fā)展不應(yīng)局限于SIP控制協(xié)議和API業(yè)務(wù)提供模式,不但要支持各種接入技術(shù),更要包容各種控制協(xié)議和業(yè)務(wù)接口,支持多種業(yè)務(wù)模式。統(tǒng)一IMS體現(xiàn)了以IMS為基礎(chǔ)探索未來信息網(wǎng)絡(luò)融合的研究方向。
  6.參考文獻
  [1]SIP:SessionInitiation Protocol[R]. RFC3261. 2002.
  [2]3GPPTS23.198V7.3.0. Open Service Access (OSA) Stage 2[S]. 2007.
  [3]TISPANpublishedNGN specifications [EB/OL].
  [4]OMAEnablerand Reference Releases [EB/OL].   http://www.openmobilealliance.org/Technical/released_enablers.aspx.
  [5]3GPPTS23.228v7.10.0 IP Multimedia Subsystem (IMS) Stage 2[S].2007.
  [6]網(wǎng)絡(luò)中立性之爭[EB/OL].
  [7]Sripanidkulchaik,Ganjam a, Maggs b, et al. The feasibility of supporting large-scale live streaming applications with dynamic application end-points[C]// Proceedings of Conference on Applications, Technologies, Architectures, and Protocols for Computer Communication (SIGCOMM’04), Aug 30-Sept 3, 2004, Portland, OR, USA. New York, NY, USA: ACM, 2004: 107-120.
  作者簡介
  糜正琨,南京郵電大學通信與信息工程學院教授、博士生導師,中國通信學會會士。目前主要研究方向是下一代網(wǎng)絡(luò)技術(shù)和異構(gòu)網(wǎng)絡(luò)融合技術(shù)。曾獲江蘇省科技進步二等獎一項,信息產(chǎn)業(yè)部科技進步二等獎和三等獎各一項,已發(fā)表SCI、EI收錄論文30余篇,出版專著和國家級教材8部,申請國家發(fā)明專利4項。
通信世界網(wǎng)(www.cww.net.cn)
揭秘融合大勢下諸多不和諧 2008-06-03
從NG-SDH到PTN的多業(yè)務(wù)融合承載平臺 2008-05-30
三網(wǎng)合一:簡要分析交換機的技術(shù)現(xiàn)狀 2008-05-30
揭密顯示屏幕背后的高清晰電視技術(shù) 2008-05-30
華為王景兆:融合視訊是新媒體的發(fā)展方向 2008-05-28
分類信息:     行業(yè)_電信_文摘
