首頁(yè)>>>技術(shù)>>>融合通信
IMS與下一代電信業(yè)務(wù)網(wǎng)
葉云 董振江 2008/10/28
  摘要:當(dāng)前IP多媒體子系統(tǒng)(IMS)為核心的電信目標(biāo)網(wǎng)絡(luò)架構(gòu)缺乏大規(guī),F(xiàn)網(wǎng)部署的實(shí)際驗(yàn)證,并面臨互聯(lián)網(wǎng)技術(shù)的激烈競(jìng)爭(zhēng)。在推動(dòng)IMS業(yè)務(wù)商用的過(guò)程中,業(yè)務(wù)交付平臺(tái)(SDP)正在向一個(gè)更加融合開(kāi)放的業(yè)務(wù)提供環(huán)境(SDE)方向發(fā)展,并成為下一代電信業(yè)務(wù)網(wǎng)絡(luò)發(fā)展的主流方向。中興通訊的下一代業(yè)務(wù)網(wǎng)(NGSN)概念,通過(guò)整合各種網(wǎng)絡(luò)業(yè)務(wù)能力,實(shí)現(xiàn)數(shù)據(jù)、業(yè)務(wù)、能力和管理的統(tǒng)一,從而能夠快速提供各種增值業(yè)務(wù)、協(xié)助運(yùn)營(yíng)商在價(jià)值鏈中處于主導(dǎo)地位,很好的滿足了電信運(yùn)營(yíng)商業(yè)務(wù)網(wǎng)絡(luò)的發(fā)展需求。
  Abstract:IPMultimediaSubsystem(IMS)-based telecom target network infrastructure lacks validations of scale deploying in actual network, and faces furious competition from the Internet at the same time. Service Delivery Platform (SDP) gradually evolves to a more opening Service Delivery Environment (SDE) along with the commercial applying process of IMS, and is becoming the main direction of the development of telecom service network. By merging different network service capabilities, ZTE’s Next Generation Service Network (NGSN) can realize the unification of data, service, capability and management, help operators get a dominant position and provide value-added services with faster speed, and fulfill the developing requirements of operator’s service network perfectly.
  技術(shù)的發(fā)展,電信網(wǎng)絡(luò)出現(xiàn)了寬帶化的演進(jìn)趨勢(shì):一方面,固網(wǎng)寬帶迅猛發(fā)展,用戶數(shù)迅速增長(zhǎng);另一方面,寬帶革命正在進(jìn)入移動(dòng)領(lǐng)域,無(wú)線網(wǎng)各陣營(yíng)相繼取得技術(shù)突破,不斷提升無(wú)線網(wǎng)絡(luò)帶寬,整個(gè)電信網(wǎng)絡(luò)正在進(jìn)入寬帶化時(shí)代。而在寬帶應(yīng)用技術(shù)的發(fā)展中,全I(xiàn)P成為不可阻擋的市場(chǎng)選擇,出現(xiàn)了IP over Everything的發(fā)展趨勢(shì)。整個(gè)電信網(wǎng)絡(luò)正在沿著核心網(wǎng)——接入網(wǎng)——承載網(wǎng)發(fā)展的脈絡(luò)逐步向全I(xiàn)P方向發(fā)展邁進(jìn)。
  而全I(xiàn)P網(wǎng)絡(luò)對(duì)于上層業(yè)務(wù)承載的透明化,直接推動(dòng)了業(yè)務(wù)與承載的分離,使得其成為當(dāng)前電信產(chǎn)業(yè)技術(shù)環(huán)境發(fā)展的最重要趨勢(shì)。同時(shí)隨著IP技術(shù)成為各個(gè)電信網(wǎng)絡(luò)共同的特征,通過(guò)不同的接入網(wǎng)絡(luò),客戶可以獲得一致的業(yè)務(wù)體驗(yàn),使得ICT融合和多媒體成為新業(yè)務(wù)體驗(yàn)的鮮明特征。
  就電信業(yè)務(wù)本身的發(fā)展而言,當(dāng)前世界電信市場(chǎng)正處于傳統(tǒng)語(yǔ)音電話業(yè)務(wù)走向飽和,新興業(yè)務(wù)不斷涌現(xiàn)并初步形成規(guī)模,而傳統(tǒng)電信業(yè)與互聯(lián)網(wǎng)產(chǎn)業(yè)之間日益融合,傳統(tǒng)電信運(yùn)營(yíng)觀念面臨巨大變革的時(shí)期[1]。一方面,電信運(yùn)營(yíng)商急需通過(guò)新業(yè)務(wù)應(yīng)用的引入開(kāi)拓新的發(fā)展空間,尋求新的利潤(rùn)增長(zhǎng)點(diǎn),并希望通過(guò)控制業(yè)務(wù)價(jià)值鏈從而維持運(yùn)營(yíng)商的傳統(tǒng)主導(dǎo)地位;另一方面,從互聯(lián)網(wǎng)成長(zhǎng)起來(lái)的新一代網(wǎng)絡(luò)服務(wù)提供商獲得了巨大發(fā)展,希望借助電信發(fā)展中業(yè)務(wù)與承載網(wǎng)絡(luò)分離的歷史機(jī)會(huì),實(shí)現(xiàn)網(wǎng)絡(luò)運(yùn)營(yíng)商與服務(wù)提供商的分離,并通過(guò)控制內(nèi)容提供從而主導(dǎo)業(yè)務(wù)環(huán)境。
  運(yùn)營(yíng)商主導(dǎo)的電信增值業(yè)務(wù)和服務(wù)提供商、內(nèi)容提供商主導(dǎo)的互聯(lián)網(wǎng)業(yè)務(wù)之間出現(xiàn)融合和滲透,其競(jìng)爭(zhēng)力量消長(zhǎng)決定了未來(lái)電信業(yè)務(wù)的發(fā)展走勢(shì)。電信運(yùn)營(yíng)的核心競(jìng)爭(zhēng)力在于業(yè)務(wù)生態(tài)環(huán)境的控制力。新業(yè)務(wù)的發(fā)展主導(dǎo)權(quán)和控制權(quán),成為未來(lái)電信發(fā)展走向的競(jìng)爭(zhēng)焦點(diǎn)。
  IP多媒體子系統(tǒng)(IMS)是電信業(yè)在全I(xiàn)P的未來(lái)網(wǎng)絡(luò)環(huán)境下實(shí)現(xiàn)業(yè)務(wù)的接入及管理控制的主流解決方案,其核心思想是在透明的全I(xiàn)P網(wǎng)絡(luò)環(huán)境下,增加由運(yùn)營(yíng)商所控制的業(yè)務(wù)控制平面,從而保證運(yùn)營(yíng)商在未來(lái)電信業(yè)務(wù)發(fā)展中的主導(dǎo)地位。IMS概念在3GPP R5中提出以來(lái),逐步完善,并得到3GPP2、ETSI、ITU-T等標(biāo)準(zhǔn)化組織以及國(guó)際范圍內(nèi)電信運(yùn)營(yíng)商、設(shè)備制造商的廣泛支持。基于IMS的電信目標(biāo)網(wǎng)絡(luò)架構(gòu)成為未來(lái)電信網(wǎng)絡(luò)發(fā)展的主流方向。
  但必須看到的是,目前IMS的地位仍未穩(wěn)固,并面臨互聯(lián)網(wǎng)技術(shù)的激烈競(jìng)爭(zhēng)。如何基于IMS的基礎(chǔ)架構(gòu),迅速推出豐富的新型業(yè)務(wù)應(yīng)用,并以之牢牢抓住電信客戶群,成為世界范圍內(nèi)電信運(yùn)營(yíng)商正在努力搶占的發(fā)展制高點(diǎn)。其未來(lái)發(fā)展,將直接決定全I(xiàn)P環(huán)境下電信與互聯(lián)網(wǎng)之間競(jìng)爭(zhēng)的消長(zhǎng)走向。
  本文對(duì)當(dāng)前IMS業(yè)務(wù)發(fā)展?fàn)顩r,以及業(yè)務(wù)提供環(huán)境(SDE)與IMS發(fā)展的關(guān)系進(jìn)行了總結(jié)和分析。并對(duì)中興通訊在深刻理解未來(lái)業(yè)務(wù)網(wǎng)絡(luò)發(fā)展趨勢(shì)的基礎(chǔ)上,提出的下一代電信業(yè)務(wù)網(wǎng)(NGSN)進(jìn)行了深入探討。
1.IMS業(yè)務(wù)發(fā)展現(xiàn)狀
  2006年以來(lái)盡管IMS在國(guó)內(nèi)外的一系列試驗(yàn)及試點(diǎn)中取得了明顯的進(jìn)展,但以IMS為核心的電信目標(biāo)網(wǎng)絡(luò)架構(gòu)仍缺乏大規(guī)模現(xiàn)網(wǎng)部署的實(shí)際驗(yàn)證,并面臨互聯(lián)網(wǎng)技術(shù)的激烈競(jìng)爭(zhēng)。筆者在2005年曾撰文指出,IMS本身存在的最大軟肋在于其始終缺乏有吸引力的特色業(yè)務(wù),而現(xiàn)有業(yè)務(wù)平臺(tái)/引擎又缺乏向IMS遷移的市場(chǎng)動(dòng)力,使得IMS的未來(lái)發(fā)展存在不確定因素。由于存在這一明顯軟肋,IMS面臨著與數(shù)年前Parlay/OSA業(yè)務(wù)體系架構(gòu)類(lèi)似的困境,即:雖然基于IMS的業(yè)務(wù)體系架構(gòu)具有一系列優(yōu)勢(shì),但運(yùn)營(yíng)商目前盈利的業(yè)務(wù)沒(méi)有一種是基于IMS運(yùn)營(yíng)的,而是采用了智能網(wǎng)、短信、WAP、流媒體等其他的業(yè)務(wù)平臺(tái)/引擎,并已經(jīng)進(jìn)行了很大的建設(shè)投入。那么,為什么要放棄已經(jīng)成熟商用的業(yè)務(wù)平臺(tái)而將業(yè)務(wù)遷移到尚未規(guī)模驗(yàn)證的IMS基礎(chǔ)之上呢?這使得IMS缺乏大規(guī)模市場(chǎng)部署的驅(qū)動(dòng)力。這一現(xiàn)狀也使得即便在IMS大規(guī)模部署以后,運(yùn)營(yíng)商仍將面臨IMS業(yè)務(wù)與non-IMS業(yè)務(wù)長(zhǎng)期共存的局面[2]。
  對(duì)于IMS所采用的基礎(chǔ)會(huì)話初始協(xié)議(SIP)對(duì)業(yè)務(wù)的支撐能力,懷疑的聲音仍不斷出現(xiàn)。2006年即有專家指出SIP只是建立和斷開(kāi)“會(huì)話”,而對(duì)正在進(jìn)行的會(huì)話過(guò)程管理甚微,而無(wú)線通信的特點(diǎn)恰恰是在移動(dòng)過(guò)程中網(wǎng)絡(luò)連接狀態(tài)的不穩(wěn)定,因而必須不斷地對(duì)會(huì)話過(guò)程進(jìn)行管理和監(jiān)控,并得出結(jié)論認(rèn)為SIP并不是一種適于無(wú)線通信的協(xié)議。同時(shí)一個(gè)明顯的現(xiàn)實(shí)是,目前不論是電信業(yè)務(wù)還是互聯(lián)網(wǎng)應(yīng)用,SIP應(yīng)用的業(yè)務(wù)量都只占很小的比例,遠(yuǎn)遠(yuǎn)沒(méi)有成為業(yè)務(wù)/應(yīng)用的主流。因此,業(yè)務(wù)應(yīng)用向IMS平臺(tái)遷移的過(guò)程,在底層可以描述為將原來(lái)的non-SIP應(yīng)用改造為SIP應(yīng)用的過(guò)程,工作量(尤其是將業(yè)務(wù)標(biāo)準(zhǔn)化的工作量)顯然是非常巨大的。
  這一軟肋在2006年和2007年表現(xiàn)愈加明顯。由于現(xiàn)有電信業(yè)務(wù)平臺(tái)/引擎向IMS大規(guī)模遷移的趨勢(shì)一直沒(méi)有出現(xiàn),使得IMS即使在試驗(yàn)網(wǎng)部署中也不得不考慮這樣一個(gè)問(wèn)題,即:如何使持有IMS終端的用戶仍能夠繼續(xù)使用原來(lái)已經(jīng)非常習(xí)慣的non-SIP應(yīng)用?從另一個(gè)角度來(lái)看,如果部署的IMS方案對(duì)占運(yùn)營(yíng)商網(wǎng)絡(luò)流量大部分的non-SIP應(yīng)用都無(wú)法控制,那么運(yùn)營(yíng)商將仍然無(wú)法避免成為管道提供商的命運(yùn),則IMS存在的基本價(jià)值也就消失了。
  為了解決這一迫切的問(wèn)題,過(guò)去一年中一個(gè)新的思路正逐步出現(xiàn),即:如果不能把原來(lái)的non-SIP應(yīng)用改造為SIP應(yīng)用,那么就擴(kuò)展原來(lái)的IMS業(yè)務(wù)體系架構(gòu)本身,使其在管理控制SIP應(yīng)用的基礎(chǔ)上,也能夠管理控制non-SIP和non-IMS的應(yīng)用[3]。在這一新的思路下,出現(xiàn)了新的發(fā)展動(dòng)向:在IMS之上建立開(kāi)放融合的業(yè)務(wù)提供環(huán)境(SDE), 實(shí)現(xiàn)non-SIP和non-IMS業(yè)務(wù)的統(tǒng)一管理控制和業(yè)務(wù)提供,以滿足下一代業(yè)務(wù)發(fā)展需要[4]。
2. IMS與SDE
  SDE是在業(yè)務(wù)交付平臺(tái)(SDP)基礎(chǔ)上進(jìn)一步擴(kuò)展提出的。SDP本身并不是一個(gè)新的概念,一般認(rèn)為SDP是一個(gè)多組件平臺(tái),通過(guò)其減少?gòu)臉I(yè)務(wù)開(kāi)發(fā)到提供給用戶的時(shí)間,減少運(yùn)維費(fèi)用,減少開(kāi)發(fā)風(fēng)險(xiǎn)。一方面,SDP形成一整套標(biāo)準(zhǔn)開(kāi)放的能快速開(kāi)發(fā)、提供、運(yùn)行、管理和計(jì)費(fèi)的增值業(yè)務(wù)的管理系統(tǒng);另一方面,SDP能夠與運(yùn)營(yíng)商IT基礎(chǔ)設(shè)施緊密結(jié)合,充分利用運(yùn)營(yíng)支撐系統(tǒng)門(mén)戶服務(wù)器的資源。SDP技術(shù)本身仍在積極地探索之中,到目前為止對(duì)SDP的組成結(jié)構(gòu)還沒(méi)有完全達(dá)成一致意見(jiàn)。不同的設(shè)備廠商在過(guò)去數(shù)年中提出了各自的理解和產(chǎn)品解決方案,并已經(jīng)在一些運(yùn)營(yíng)商作為一種通用的業(yè)務(wù)架構(gòu)提供如本地號(hào)碼攜帶、預(yù)付費(fèi)以及800業(yè)務(wù)等電信業(yè)務(wù)。
  SDE在SDP平臺(tái)之上進(jìn)行了拓展。按照咨詢公司Current-Analysis的定義,SDE是實(shí)現(xiàn)IMS業(yè)務(wù)應(yīng)用和non-IMS業(yè)務(wù)應(yīng)用(如Web應(yīng)用和智能網(wǎng)業(yè)務(wù))管理控制的通用架構(gòu)。其將IMS提供的優(yōu)勢(shì)與SDP結(jié)合起來(lái),并具有如下特征:
  SDE是推動(dòng)運(yùn)營(yíng)商業(yè)務(wù)網(wǎng)絡(luò)層次從垂直到水平的轉(zhuǎn)變的機(jī)制,使得業(yè)務(wù)能夠快速提供和退役,促使網(wǎng)絡(luò)資源得以重用,并更加容易的開(kāi)發(fā)和提供以客戶為中心的定制化業(yè)務(wù)。
  SDE可以充分利用IMS體系提供的業(yè)務(wù)機(jī)制,使得二者密不可分。從IMS體系架構(gòu)的角度來(lái)看,SDE是IMS在業(yè)務(wù)層次的擴(kuò)展。
  SDE使得其他的主流業(yè)務(wù)應(yīng)用(如IPTV)與IMS業(yè)務(wù)處于一個(gè)統(tǒng)一的業(yè)務(wù)框架之下。通過(guò)SDE,IMS提供的業(yè)務(wù)能力(如狀態(tài)呈現(xiàn)、移動(dòng)性管理、策略管理等),可以與非SIP/IMS域的業(yè)務(wù)實(shí)現(xiàn)交互,從而推動(dòng)IMS業(yè)務(wù)的商用部署。
  通過(guò)SDE,允許引入第三方業(yè)務(wù)應(yīng)用,甚至通過(guò)網(wǎng)關(guān)等方式引入基于互聯(lián)網(wǎng)的業(yè)務(wù)應(yīng)用,從而帶給電信客戶更加豐富的業(yè)務(wù)體驗(yàn),提升運(yùn)營(yíng)商業(yè)務(wù)的市場(chǎng)競(jìng)爭(zhēng)力。
  SDE與現(xiàn)有的業(yè)務(wù)平臺(tái)實(shí)現(xiàn)后向兼容,保護(hù)運(yùn)營(yíng)商投資,并帶給用戶一致的業(yè)務(wù)體驗(yàn)。
  典型的SDE架構(gòu)如圖1所示[5]
  3.下一代電信業(yè)務(wù)網(wǎng)發(fā)展思路
  綜上所述,在推動(dòng)IMS業(yè)務(wù)商用的過(guò)程中,SDP業(yè)務(wù)平臺(tái)正在向一個(gè)更加融合開(kāi)放的SDE業(yè)務(wù)環(huán)境方向發(fā)展,并成為下一代電信業(yè)務(wù)網(wǎng)絡(luò)發(fā)展的主流方向。在這種情況下,中興通訊提出的下一代業(yè)務(wù)網(wǎng)(NGSN)概念,很好的滿足了電信運(yùn)營(yíng)商業(yè)務(wù)網(wǎng)絡(luò)的發(fā)展需求。
  NGSN是為了適應(yīng)網(wǎng)絡(luò)和技術(shù)的融合趨勢(shì)、運(yùn)營(yíng)商轉(zhuǎn)型的需求提出的,通過(guò)整合各種網(wǎng)絡(luò)業(yè)務(wù)能力,實(shí)現(xiàn)數(shù)據(jù)、業(yè)務(wù)、能力和管理的統(tǒng)一,從而能夠快速提供各種增值業(yè)務(wù)、協(xié)助運(yùn)營(yíng)商在價(jià)值鏈中處于主導(dǎo)地位。其概念層次如圖2所示。
  NGSN對(duì)最終用戶而言,可以讓其享受到與用戶賬戶、位置、狀態(tài)、偏好以及共享內(nèi)容等屬性標(biāo)記相關(guān)的個(gè)性化的業(yè)務(wù)和更為方便的統(tǒng)一體驗(yàn)。例如用戶可以尋求就近的協(xié)作伙伴進(jìn)行緊急工作溝通,獲取用戶喜歡的品牌商品的打折信息并及時(shí)訂購(gòu),合并來(lái)自各種電子傳媒的欄目,定制推送用戶感興趣的電子報(bào)紙,用戶自己創(chuàng)建娛樂(lè)內(nèi)容并提供給其他用戶,與運(yùn)營(yíng)商分享收益等。
4.結(jié)束語(yǔ)
  隨著電信網(wǎng)絡(luò)的寬帶化和全I(xiàn)P演進(jìn),電信業(yè)務(wù)網(wǎng)絡(luò)面臨著互聯(lián)網(wǎng)的激烈融合與競(jìng)爭(zhēng)。IMS業(yè)務(wù)的發(fā)展現(xiàn)狀,要求擴(kuò)展原來(lái)的IMS業(yè)務(wù)體系架構(gòu)本身,使其在管理控制SIP應(yīng)用的基礎(chǔ)上,也能夠管理控制non-SIP和non-IMS的應(yīng)用。在推動(dòng)IMS業(yè)務(wù)商用的過(guò)程中,SDP業(yè)務(wù)平臺(tái)正在向一個(gè)更加融合開(kāi)放的SDE業(yè)務(wù)環(huán)境方向發(fā)展,并成為下一代電信業(yè)務(wù)網(wǎng)絡(luò)發(fā)展的主流方向。中興通訊的下一代業(yè)務(wù)網(wǎng)(NGSN)概念,是適應(yīng)網(wǎng)絡(luò)和技術(shù)的融合趨勢(shì)、運(yùn)營(yíng)商轉(zhuǎn)型的需求提出的,通過(guò)整合各種網(wǎng)絡(luò)業(yè)務(wù)能力,實(shí)現(xiàn)數(shù)據(jù)、業(yè)務(wù)、能力和管理的統(tǒng)一,從而能夠快速提供各種增值業(yè)務(wù)、協(xié)助運(yùn)營(yíng)商在價(jià)值鏈中處于主導(dǎo)地位,很好的滿足了電信運(yùn)營(yíng)商業(yè)務(wù)網(wǎng)絡(luò)的發(fā)展需求。
5.參考文獻(xiàn)
  [1]王映.電信和互聯(lián)網(wǎng)的交融與博弈[R].北京:信息產(chǎn)業(yè)部電信研究院通信信息研究所, 電信決策咨詢專題研究報(bào)告, 2007.
  [2]JONEN,GUTBERLET M. IMS Will Not Enable Innovative Services[R]. Gartner, 2006.
  [3]MCGARVEYJ.Beyond IMS: Building out a Service Delivery Environment [R]. 2006.
  [4]AdvancestoIP Multimedia Subsystem (A-IMS) Architecture [S]. 2006.
[5]ANDERSONJ.Service Delivery Environment at TeliaSonera [R]. TeliaSonera, 2006.
作者簡(jiǎn)介:
  葉云,中興通訊股份有限公司方案營(yíng)銷(xiāo)部方案規(guī)劃總工。碩士畢業(yè)于清華大學(xué),長(zhǎng)期從事業(yè)務(wù)&軟件產(chǎn)品預(yù)研和產(chǎn)品規(guī)劃工作,已公開(kāi)發(fā)表論文40余篇。董振江,中興通訊股份有限公司業(yè)務(wù)研究院規(guī)劃副院長(zhǎng)、公司技術(shù)專家委員會(huì)業(yè)務(wù)組組長(zhǎng)。碩士畢業(yè)于哈爾濱工業(yè)大學(xué),先后從事交換機(jī)和智能網(wǎng)等開(kāi)發(fā)、設(shè)計(jì)和規(guī)劃等工作,研究方向?yàn)镾DP、P2P、業(yè)務(wù)引擎、3G業(yè)務(wù)和ICT等。參與和負(fù)責(zé)過(guò)多項(xiàng)國(guó)家發(fā)改委的技術(shù)課題,發(fā)表過(guò)多篇增值業(yè)務(wù)相關(guān)文章。
通信世界網(wǎng)(www.cww.net.cn)
融合業(yè)務(wù)呼喚分層監(jiān)管 2008-10-28
Dialogic公司總裁專訪:技術(shù)為本,整合資源,迎接挑戰(zhàn) 2008-10-27
愛(ài)立信基于IMS的固網(wǎng)移動(dòng)融合(FMC)解決方案 2008-10-27
通信展:固定移動(dòng)融合(FMC)掀起新高潮 2008-10-24
IMS:已贏得運(yùn)營(yíng)商的信任 2008-10-22
分類(lèi)信息:     行業(yè)_電信_(tái)文摘
